Puma 1.7 Problem
Old Oct 15, 2011 | 10:39 PM
RB26DETT's Avatar
RB26DETT
Default Puma 1.7 Problem
Hi Guys,
My 1.7 has a missfire at idle but drives okay otherwise?
Possible problems?
Should have a video up tomorrow
Thanks
Old Oct 15, 2011 | 10:46 PM
alexno1dj's Avatar
alexno1dj
Id start by cleaning the MAF and a set of new plugs, while your there check the rocker cover gasket isnt leaking
Old Oct 16, 2011 | 03:57 PM
RB26DETT's Avatar
RB26DETT
Cheers, sounds more internal... But will do that, I'll post a video in a while of it running.
Old Oct 16, 2011 | 06:47 PM
alexno1dj's Avatar
alexno1dj
that would definatley be my first port of call, then if it is still miss firing you have dealt with the most common probs first
Old Oct 16, 2011 | 06:58 PM
RB26DETT's Avatar
RB26DETT
Just started it for the first time in a while there, and it's not as bad as I thought.
I'll put up the video in a min.... It clears after 3k revs.
Old Oct 16, 2011 | 07:23 PM
alexno1dj's Avatar
alexno1dj
yeah i think what ive suggested should sort it mate
Old Oct 16, 2011 | 08:38 PM
RB26DETT's Avatar
RB26DETT
http://www.youtube.com/watch?v=vghnqWFrxmo
Old Oct 19, 2011 | 06:44 PM
RB26DETT's Avatar
RB26DETT
Right checked plugs and MAF..... Still the same...
Anything else to try? I'v another engine hear so can swap over bits
Old Oct 19, 2011 | 06:50 PM
alexno1dj's Avatar
alexno1dj
what about the coil pack? take the one from your other engine and swap it over.
Old Oct 19, 2011 | 07:38 PM
RB26DETT's Avatar
RB26DETT
Already tryed a coil pack... But I took it off my 1.4 Puma, was still the same.
It has to be simple as the car still drives perfect
Old Oct 19, 2011 | 07:51 PM
Churtz's Avatar
Churtz
Have you got a maf to try? I know you've cleaned it, but got to be worth a switch if donor is available. They are very common to fail. On the hot-wire.
Matt
Old Oct 19, 2011 | 08:58 PM
Dal_'s Avatar
Dal_
I'd guess the Idle Control Valve.
It fits diamond kinda shape where those two little holes are on the inlet.
Old Oct 19, 2011 | 09:28 PM
mk1turboestate's Avatar
mk1turboestate
i had one that did the same, tried loads of things, ended up puttin new leads and plugs on and it was sorted
Old Oct 19, 2011 | 09:31 PM
alexno1dj's Avatar
alexno1dj
that's usually the problem when they do this.
Old Oct 20, 2011 | 03:20 PM
RB26DETT's Avatar
RB26DETT
Have swapped in another MAF.
Have swapped in another Idle Control Valve.
Will just try leads and plugs (I think I already tried it, but sure what harm)
Thanks for the help guys.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DAZZER
Sep 30, 2015 08:43 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
