erst/mk5 engine mount/gearbox
Old Feb 17, 2005 | 04:33 PM
monty's Avatar
monty
Default erst/mk5 engine mount/gearbox
i have just put an erst engine into my mk5 cossie replica and i cant get the front engine mount to fit the engine i took the mount off had a bit on the g/box for the mount to bolt to but the turbo 1 doesnt.
i no the conversion has happend a good few time before so there must be mount that i can use
any help would be great
cheers
Old Feb 17, 2005 | 09:04 PM
b13nde's Avatar
b13nde
was yours a zetec if so you wont have a front mount on the engine now erst only uses three 2 gear box and one back of engine i think you need to mod the rear mount its only a case of cutting a bit off
Old Feb 18, 2005 | 05:04 PM
monty's Avatar
monty
no it was a turbo diesel before, its the front gearbox mount im after
thanks
Old Feb 18, 2005 | 11:32 PM
s3rst's Avatar
s3rst
r u using the s1 box? the mk5 and s1 turbo have the same setup, i put one in my mk5.
the mk 4 rst uses a cradle. i do have a mount somewhere from mine, but the old one from the escort should fit the s1 box or keep the desel box in?
the s1 box has 4 holes at the front to mount it with. s2 turbo box uses cradle.
Old Feb 19, 2005 | 01:28 PM
monty's Avatar
monty
its a s2 box was thinking about putting the diesel box back in but would prefer to use the turbo 1
Old Feb 19, 2005 | 09:38 PM
s3rst's Avatar
s3rst
u can rebuild the desel box to use rst internals. or just buy a series one box, both seem to fetch the same sort of cash... shame im a bit poor at the mo i need a s2 box
use the desel one and fit lsd from yr box for now? generally desel boxes are meant to be stronger
Old Feb 20, 2005 | 10:22 AM
monty's Avatar
monty
cheers mate will give that a go but is the desiel box not slower on the take off? coz its geared differntly
Old Mar 6, 2005 | 07:42 PM
monty's Avatar
monty
ok tried to swap gearboxes and the shaft that comes out the box is bigger on the desiel box than on the turbo 1 so it doesnt fit into the fly wheel or clutch so i tried to use the deseil flywheel and clutch but it doesnt fit on
any help would be good
cheers
Old Mar 9, 2005 | 10:31 PM
16vzetec's Avatar
16vzetec
the mk4 box doesnt fit into the mk5.
use a mk5 cvh box.
the gearbox from the mk5 1.6cvh efi has got to be the same shaft size, if it aint i'll eat mt hat!!
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
