Cossie heater
Old Feb 17, 2005 | 02:37 PM
Mrs_Ricky_3dr's Avatar
Mrs_Ricky_3dr
Default Cossie heater
The heater is fine running around town but on motorways the heater is useless
Recently fitted a brand new, genuine Ford thermostat.
Has anybody else had this problem? How was it rectified?
Old Feb 17, 2005 | 02:42 PM
Alvyn's Avatar
Alvyn
maybe the heater matrix is blocked also try taking the 2 pipes of the heater and put a hose pipe through it failing that maybe a new one BUT dash has to be removed well most of it to do it
Old Feb 20, 2005 | 02:40 PM
sbon's Avatar
sbon
yes have the same problem with mine saff cosworth have fited new rad and thermostat and now dose not get very hot or takes long time .
the temp gauge sits low on the gauge around town is there a different thermostat i can use ?????
Old Feb 20, 2005 | 05:21 PM
mick320BHP's Avatar
mick320BHP
try swapping the two hoses under the bonnet for a few miles might a air lock in internal heater have tried and does work
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
