Mondeo passenger door won't open
Old Sep 3, 2011 | 09:49 AM
Fitpaul's Avatar
Fitpaul
Default Mondeo passenger door won't open
I have 1988 Ghia x Mondeo and the passenger door wont open from the inside or outside.
Central locking, key or inside handle don't work. I have manged to partially remove the door card and see the lock. None of the handle linkages are detached or broken. How can I open the door?
Old Sep 3, 2011 | 10:18 AM
gouch1's Avatar
gouch1
on the back of the lock there is a small leaver try moving that
if that dont work it will be the latch downthe side of the door near middle again try moving bar or mechanism
Old Sep 3, 2011 | 10:34 AM
Fitpaul's Avatar
Fitpaul
Thanks for your response.
It is covered with a white plastic cover that I can't remove. Should I smash it? Is the lever visible or is it behind the lock?
Down the side of the door? I can't open the door.
Old Dec 21, 2012 | 03:47 PM
Wasp's Avatar
Wasp
Smile Passenger Door Won't Open
My problem was that the passenger door on my Mondeo would not open from the outside --- only from inside the car . After reading some tips here I found that if you place your right hand on the door above the handle , push the door and at the same time pull on the handle it releases the catch and the door will open ! Ta Darr !!!
Old Dec 21, 2012 | 04:40 PM
Fordmad!'s Avatar
Fordmad!
Get someone to hold the handle up and kick it from the inside i did this in my escort then fixed it when the door was open
Old Dec 21, 2012 | 05:15 PM
D-Sport's Avatar
D-Sport
I also bought a mondeo with a stuck door and I shoved my shoulder against it and hey presto it worked
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
