2.5 Duratec L5 five-cilinder in a MK4 Escort?
Seriously Newbie
Well think my idea's for my mk4 XR3i's resto are going out of the box....
I'm allready on the hunt for 2.0 zetec's and Duratec's, saw this 2.5 ST engine laying around.... got that would be
anyone got any idea's on this? I'm blank bout what to modify, what box 2 use, etc.
For logics, if it would be easy then it must have been done before, but here, there's always a first time isnt it?
This was 1 of the first mk4's to have both the 2.5 and 3ltr V6 lump in
http://www.youtube.com/watch?v=1nSss7qBkDI&feature=fvsr
Seriously Newbie
Ugh... feel the same here...
On-topic, yeah i think the lump is way to big, would need to chop a fair bit out of EVERYTHING under the bonnet to make everything fit, and then there is the gearbox issue, the drive shafts, width of the car....
Think I'll stick to a 2.0 four-banger zetec or duratec....
An eye for detail...
It could be done, but you'd need a blank canvas.
To do it properly you'd want to brace the front end so it stays square and doesn't twist, then cut everything from the heater motor panel to the crossmember out, so you're just left with the bulkhead, outer wings, front panel and chassis leg stub sections.
Lift the 2.5 in with it's own gearbox on the subframe etc so it sits in the right place, frame around it so it makes a new front end around subframe. Then use focus hubs, brakes, suspension strut/strut tops etc and shorten original shafts, cable gear linkage is a doddle. If the original shaft splines will fit into the mk4 hubs (which i doubt, but possible), then you could modify the original mounts and parts with the shortened shafts to save some money.
This would be easiest if you can get hold of a salvage focus to cut a few chunks out of like the lower arm mounts etc to save time and effort. You'd end up with a semi-space framed front end, leaving plenty room for pipework, wiring etc.
It can be done, and relatively easily if you've got the time. And yes i've thought about this in some detail cause i think it'd be AMAZING.
On the subject of Duratec, if you need any ideas on mounts, i've converted my inner wing to take a Blacktop zetec or duratec mount.
However, I still think space would be tight! And if you went through all that, you might as well make it RWD to be honest.
V6 Ka of Love
**edit sorry, I thought for some reason you were asking about the 2.5 v6
i bought a focus st engine for my mk5 escort as one came up dirt cheap, once it got here and i measured it up it was a very tight fit!
im sure it can be done as there was a mk6 fiesta on ebay which had the 2.5st engine in but itll take alot of fab work to make it work, something i didnt want to be doing with the tools and knowledge i have..
its deffinatly possible, anything is with cars but you have to know what your doing
A focus st was converted to rwd a wile back, if im not mistaken, used a granny rear axle, was a drift car and sponsored by some energy drink, was featured in one of the ford magazine
Ben
Why not rear mount it if you want to do something daft?
I've read/heard about a firm that will convert a focus rs or st to 4wd using Kuga 4x4 parts, apparently it all bolts straight in perfectly, no fabricating involved.
3dr Cosworth owner
Wolf tuning in germany. Kuga rear axle and modify the gearbox to add a transfer box. Rear axle sits about 3mm further forward i believe
theres a 100e pop with a st 2.5t drysumped with vipec in the resto section.....
as above i would spaceframe the front end but make it full adjustable at the sametime.....
anything is possible, i know of a mk4 escort cab with a 2.0ltr zt in the boot on a mondeo subframe, and have seen a k20 vtec in a fwd escort.....
i wanted to do this very conversion when an engine came up cheap on here
Adam Graham
06-09-2015 06:04 AM
