p100 fuel tank
Old Aug 31, 2011 | 09:25 AM
p100rallyesport's Avatar
p100rallyesport
Default p100 fuel tank
Hello all does anyone know how to remove the fuel tank from a 1990 (g) p100, do you need to remove the rear tub to get it off or can it be removed without touching the tub???????
I am changing from a diesel engine to a petrol pinto engine are all the tanks the same or do they differ from diesel and petrol models???
THANKS IN ADVANCE FOR ANY HELP
Old Aug 31, 2011 | 11:00 AM
p100rallyesport
Also for the swap can i use the diesel gearbox (does it marry straight up to the pinto block??) and can i use the diesel loom or is it best to change the loom
i have two p100's on the drive side by side one is diesel and the other petrol??
thanks again
Old Aug 31, 2011 | 12:30 PM
cozmeister's Avatar
cozmeister
More boost Igor!
At the risk of being completely useless, the Haynes comic has the answer to removing the tank.
Is it an EFI Pinto you're using? Even if you're not, I reckon you'll need the loom as the engine loom's integrated with the main loom.
Old Aug 31, 2011 | 12:38 PM
p100rallyesport
no mate it is 2.0 on carb
either way i have both so no issue just seeing if anyone knows
Old Aug 31, 2011 | 07:20 PM
p100rallyesport
how about gearbox will a diesel box marry up to a 205 pinto block??
Old Sep 20, 2011 | 10:55 PM
ally261's Avatar
ally261
Default tank.
take off the tub to get at the tank, 6 torx is all thats holding it, tank and box will do on either
Old Oct 7, 2011 | 08:28 PM
bortaf's Avatar
bortaf
bit late but the diesel box is a V6 box and wont fit the pinto without cutting the inpust shaft down and even then you need to change the B/H to a petrol one or the starter wount engauge the ringear
timsrs
Nov 13, 2018 11:48 AM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
