IB5 help !!!!
Old Aug 30, 2011 | 11:43 AM
forfi_xr2's Avatar
forfi_xr2
Default IB5 help !!!!
I install in a ib5 gearbox with rear starter mount a quaife differential with new bearings and ford racing puma internals , the problem is in the diff, when I close the gearbox it's blocked!!! no running free!! I don´t know whats happening
Old Aug 30, 2011 | 06:32 PM
Churtz's Avatar
Churtz
Did u get the diff shimmed correctly?
Old Aug 30, 2011 | 07:33 PM
2ndGear's Avatar
2ndGear
the diff crown wheels are different thickness on the ib5
Old Sep 1, 2011 | 08:23 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Try and mark the edge of the crownwheel with a marking dye, engineers blue or similar, make sure inside of gearbox casing is clean, and bolt it together quick, it should leave blue dye anywhere it touches the case, then you can file/machine/grind it back to fit?
Old Sep 2, 2011 | 08:05 PM
forfi_xr2's Avatar
forfi_xr2
the problem was with 4th gear main shaft . I will put a photo
druidgetafix
Aug 15, 2015 10:22 AM
RsS2daz
Aug 14, 2015 05:26 AM
supermanrs
Aug 13, 2008 07:50 PM
wywywywy
Dec 24, 2004 04:37 PM
