Cossie Thermostat
Having an ongoing issue with my 2wd thermostat not operating properly. I bought an 82deg one from MSD and it was faulty, as it was sticking open. The replacement they sent is now doing the oposite and sticking closed.
Can someone confirm which way the stat goes into the housing. Mine have always been fitted as per picture 1 and never had an issue before.....
or
or
The first picture is wrong, the second picture is right. The spring should be facing into the head. If I remember right, the stat has an arrow to remind you before you bolt it up
When refitting use a re-usable cometic gasket.
Are you sure, I know the 4wd stats fit with the sping inwards, but the the workshop manual show the 2wd stat the other way round. Got no arrows on these ones, and the original one came out as in picture 1.
The Haynes book of lies tells the truth, ironically, so I've got to see Ford's little whoopsie to believe it.
The stat's there to make sure water doesn't get INTO the rad until the coolant's hot enough to warrant cooling down again. Water goes into the rad at the top, and out of the rad at the bottom...
Which page of the workshop manual, I want to see
He might have just finished a few scoobies though
Who ever put the engine together before me must have a obsession with fitted things back to front as they did the same with the thrust washers on the crank and fucked the bottom end. The weird thing is it ran perfectly fine for 2k miles until I decided to put a lower temp stat in it. Just been out in it for 40 mins and its fine after changing it around...... funny that
The Enigma
Sep 29, 2015 10:31 AM
Russ Payne
Sep 25, 2015 08:29 PM
