Fitting Hi Spec Calipers to 4x4 strut....wrong brackets?
Old Aug 21, 2011 | 10:08 AM
kaisersolsay's Avatar
kaisersolsay
Default Fitting Hi Spec Calipers to 4x4 strut....wrong brackets?
Tried fitting my 360mm / 6 pot kit yesterday but the caliper brackets supplied by Hi Spec seem incorrect. Just want to check I'm not being a complete mong before I call them tomorrow. See pic below of the fitment, there's a good 15mm gap once the caliper is mounted onto the disc.
Old Aug 21, 2011 | 12:25 PM
axelriet's Avatar
axelriet
..or wrong bells?
Old Aug 21, 2011 | 01:32 PM
kaisersolsay
No the bells are new also and for a 4x4
Old Aug 21, 2011 | 01:54 PM
COLEYST200's Avatar
COLEYST200
Are the brakets for a 2wd
Old Aug 21, 2011 | 02:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
2wd brackets would be bolt through, so that lookslike it's the culprit
Old Aug 21, 2011 | 04:29 PM
kaisersolsay
The brackets were made up for my 4x4 application as they didnt have any in stock...note '4x4' stamp on the picture above. I have 2wd brackets that came with the 2nd had rotors and calipers and they are completely different and also do not fit.
It looks to me like the recesses on the brackets have been milled too far. I'll get in touch with Hi Spec tomorrow.
Old Aug 21, 2011 | 06:15 PM
adam151082's Avatar
adam151082
try turning the bracket 180 so the ''4x4-360x32'' wrighting faces the wheel and not the suspention if you get my drift.
Old Aug 21, 2011 | 10:03 PM
kaisersolsay
Tried that mate but if I turn the brackets round then the thread holes that receive the caliper bolts don't line up.
Looking at them again the brackets definitely look 10-15mm out. I'll call Hi Spec in the morning. Its just a little annoying considering the dosh I paid.
Old Aug 21, 2011 | 10:27 PM
GAZ345's Avatar
GAZ345
as said above brackets should be turned & sit this side of the hub
Old Aug 21, 2011 | 10:31 PM
dojj's Avatar
dojj
unbolt the brakcet from the caliper, poke a screwdriver though one of the vanes in the disc to hold the caliper in place and then offer up the bracket in various configurations to see if there isn't one way that it will fit
Old Aug 22, 2011 | 12:52 PM
kaisersolsay
Tried all configurations. Hi Spec are looking into it now and are coming back to me.
Old Aug 22, 2011 | 07:23 PM
kaisersolsay
Hi Spec came back to me and asked if the struts were off an XR4x4. To be honest I cant be completely sure as they were an Ebay purchase. Is there a difference between XR4x4 & Cosworth front hubs?
Old Aug 22, 2011 | 08:24 PM
dojj's Avatar
dojj
not that much, the xr ones sit 4mm further back than the cossie ones
Old Aug 22, 2011 | 09:35 PM
kaisersolsay
Perhaps that's what will make all the difference?
jason_nike
Aug 18, 2019 10:53 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
james kiely
Aug 28, 2015 08:58 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
RsS2daz
Aug 14, 2015 05:26 AM
