solid mounting engine
Old Aug 16, 2011 | 11:08 PM
bangerboy33's Avatar
bangerboy33
Default solid mounting engine
Hi got mk2 fiesta with a race built 1.3 cvh in it and all it keeps doing is ripping apart the gear box mounts have tried uprated polybush mounts but they end up the same so as a last resort i am thinking of welding bits of box between the gearbox mounts and the crossmember totally removing the rubber mounts have done similar on bangers and they r harsh ie, rattle ya fillings out but cant think of any other way to stop the engine ripping mounts
Old Aug 17, 2011 | 12:36 AM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
try some vibratechnics comp mounts, less harsh than solid, there about Ł90 i think, or try solids with a thin strip of rubber between each mounting face.
Old Aug 17, 2011 | 02:13 PM
bangerboy33
Bloody hell Ł90 didnt pay that for the car let alone a engine mount! !!!!!
Old Aug 17, 2011 | 02:29 PM
chaffe's Avatar
chaffe
Turbocharging Technician
simple solution, you can get a poly mount for penuts, when bolting it on put the bolt straight through the middle of it so it cant come appart, bit of a compromise but then thats what you get for buying a ford
bigluke200
14
Sep 2, 2015 10:35 PM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
