How do you mapp ignition timing?
Old Aug 14, 2011 | 09:11 PM
BRAM's Avatar
BRAM
Default How do you mapp ignition timing?
Hi im still tring to learn about tuning/mapping and was wondering when advancing timing how do you know when to stop obviously when you hear det, but i was thinking surely you cant just advance till you hear it then back off on every load site otherwise by the time you have fully sorted the map out you will have destroyed your engine.
Dont worry i havent done any ignition mapping yet just trying to learn.
Old Aug 14, 2011 | 09:36 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you've pretty much got it, an egt gauge would help though as you can see the heat building up before it reaches det point.
Old Aug 14, 2011 | 09:44 PM
BRAM's Avatar
BRAM
So what do you do mate do you just hold it on one load and advance till you hear det the retard a few degrees, then move to a different load?
Old Aug 14, 2011 | 09:54 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
pretty much, but as i said check egt's as that effects the engine too, might just be a case of adding/subtracting fuel into that area too.
Old Aug 15, 2011 | 11:46 AM
BRAM's Avatar
BRAM
What egt should I be seeing?
van_dogg_pavvy
Mar 3, 2016 09:30 AM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
