how to clean multi plug
Old Aug 7, 2011 | 03:29 PM
emmamas's Avatar
emmamas
Question how to clean multi plug
Hi guys
Gonna sound dumb but can you clean the brake fluid reservoir multi plug with wd40?
handbrake light stays on with no tcs light coming on and the occasional air bag flash. Car doesn't have ABS as far as i know but there is a ford approved fuse for ABS in engine bay so very confused! No ABS light has ever come on.
Changed handbrake switch so its deffo not that and when you wiggle multi plug it dims a little. Its not the brake fluid level either or the braking system.
This all started to happen the instant when my front spring went. It did fix itself for months then started again.
Any suggestions?
Thanks
Old Aug 7, 2011 | 07:59 PM
emmamas's Avatar
emmamas
Ok now my heads fooked. There is an ABS fuse in the engine bay and my master cylinder is for an ABS breaking system so why as there never been a light in the three years we've had it. Its never flashed and we thought it didn't have ABS. Looks like some numpty has took the bulb out or something. Funny thing was the handbrake light was working fine until the spring went. Now its still stuck on and the airbag likes to give me a flash now and again. Where is the ABS module so hubby can see if its damp?
gambo08
Feb 4, 2016 10:49 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
