Idle issues....again!
Old Aug 5, 2011 | 11:53 PM
RichieL's Avatar
RichieL
Default Idle issues....again!
Anybody help on my 2001 Focus 2.0 16v Zetec?
Since I have cleaned the throttle body she runs fine yet as soon as I come to stop the revs will idle at around 1,600rpm then after say 5 seconds drop to 900rpm.
I cleaned the idle control valve which was very dirty.....This has not cured it either.
I am just wondering if I did some damage to the throttle body when cleaning it? I took the throttle body off and sprayed carb cleaner all around it, this did not budge the grime that was on the back of the white plastic butterfly. So I took both screws out of the butterfly and used a fine grade sandpaper to remove the grime, all worked well and left me with a nice clean butterfly. I then used the same fine sand paper to clean inside the throttle body whilst the butterfly was out making sure that was nice and clean. Since this the idle stays high when I come to a halt which is rather annoying in traffic waiting 5 or so seconds for it to drop to 900rpm.
Only other thing I can think of is I put a full tank of Shell Optimax (99 ron) in her the same day I cleaned the throttle body......I have never used 99ron in her before but thought I would give it a try.
I also cleaned out the Idle Control Valve with carb cleaner....Still no joy
Looking on Ebay under throttle body for my Focus a few other things related are popping up like sensors.
Any ideas would be great as it rather annoying.....Although saying that I have done 50 miles driving fairly hard and my fuel gauge has not moved, still showing Full which is a good thing!
Old Aug 5, 2011 | 11:56 PM
botters's Avatar
botters
competant bodger
did you have the ignition on at all while you had the throttle body or iscv disconnected? if so it could have stored a fault
ive known (rare tho) for the clutch switch to cause high revving as well
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
