cossy headgasket
Old Feb 13, 2005 | 07:33 PM
mcgoo's Avatar
mcgoo
Default cossy headgasket
when doing a 330bhp conversion on an escos should i change the headgasket for an uprated one, i've been having mixed reviews, and if dso which one, cometic, group a, wrc etc
Old Feb 13, 2005 | 07:58 PM
Alvyn's Avatar
Alvyn
when I 1st done my saf 40000 miler to stage3 803's etc it held together for over 2 years at 20 psi with a standard head gasket on it suppose you'll get told it will blow straight away reason I change was I got a new built complete engine so change it over and the engine is still going today but NOT @ stage 3 n e more 15psi!
Old Feb 14, 2005 | 12:50 PM
Dave Henshall's Avatar
Dave Henshall
cometic 3 layer with std new bolts. 200 quid for the lot.
Old Feb 14, 2005 | 03:21 PM
alan rainbow's Avatar
alan rainbow
when i fist did stage 3 went up the road and back and head gasket leaking but my mate did his and its still going strong i think its all down to how good the gasket is at time of going stage 3
Old Feb 14, 2005 | 03:52 PM
Cossie-Iain's Avatar
Cossie-Iain
theres good deals on cometic stuff just now.If your going to do a job make it a proper job and buy something that will last like a cometic one.
Old Feb 14, 2005 | 04:52 PM
mcgoo's Avatar
mcgoo
once again, thanks for the advice guys
ps ive noticed there are two different thickness cometic gaskets, which one would i need?
Old Feb 19, 2005 | 06:17 PM
rocar's Avatar
rocar
If you are going to use MLS head gasket you must have two 100% perfect surfaces or it might leak.Use ARP head stud if you want a good job.The original and Grp As are 1.3mm thick and the Comitec ,there are the 1mm and the 1.5mm,the thicker the lower compression.
Roger
Old Feb 19, 2005 | 06:56 PM
mcgoo's Avatar
mcgoo
thanks just got the bits, got a cometic gasket off ebay for Ł100 and some new bolts from ggr
Old Feb 21, 2005 | 07:42 AM
Dave Henshall
go for the thicker one if you have had the head skimmed, it will allow to slightly drop the C/R back to standard to compensate for teh skim
Old Feb 21, 2005 | 09:26 AM
Azrael's Avatar
Azrael
I am told there are no longer two thicknesses COmetic gaskets.
Old Feb 21, 2005 | 09:45 AM
Dave Henshall
i got mine about 9 months ago and the one everyone was recomendeding was the thicker one, so perhaps they have dropped the std thickness one and now only supply the thicker one due to lack of sales for the thinner one ?
Old Feb 21, 2005 | 09:48 AM
Azrael's Avatar
Azrael
Would need answers from somebody more competent then I am. I've got two gaskets just in front of me and I don't think they are more then 1.1, 1.2 mm
Old Mar 22, 2005 | 02:13 PM
2wd's Avatar
2wd
Hi the new cometic should be 1.3 mm..
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
