Whirring Noise
Old Feb 13, 2005 | 03:23 PM
Nik_W's Avatar
Nik_W
Default Whirring Noise
My Cossie always had a whirring noise to it last year and I thought nothing of it. But after reading about cambelt tensioners, etc. I thought I may aswell mention it. I have just changed the cambelt and replaced the power steering and alternator belts and the noise is very noticable. the car hasn't been on the road since last october as she is having a fair few bits changed. I took the cambelt tensioner off and it seemed to spin freely in my hand with no play, etc. so I thought it would be ok to reuse. The noise can't be the power steering pump because I never had a belt on it for most of last Summer So, could it be the cambelt tensioner, or something else? I have never renewed a cambelt tensioner on any car in the past, but from what I have read elsewhere it seems to be the done thing on the YB.
Old Feb 14, 2005 | 10:46 AM
Simmo's Avatar
Simmo
when you replaced the cambelt you didn't tension it too tight did you?... cos that can cause the whirring noise, i know i've done it myself!!! As for replacing the tensioner, it would probably be worth it if you don't know whether its been done before or if it looks a bit tired.
Old Feb 14, 2005 | 11:21 AM
Nik_W's Avatar
Nik_W
No the belt wasn't too tight, just spoke to Harvey Gibbs and he said it sounds like it could be the tensioner. I am gonna replace anyway, if it turns out to be something else then so be it.
Old Mar 5, 2005 | 03:54 PM
Nik_W's Avatar
Nik_W
Right, I took my tensioner to harvey and he confimred that it was fooked. I bought a new one and put it on. However, there is still a whirring noise. I am pretty certain it was coming from the camshaft area so I took the rocker off and took the exhuast cam out to take a look at the bearings. I slipped the bearings off, they weren't spinning very freely but after a clean up they are now spinning a bit better. There is a little bit of play in them aswell. I haven't checked the inlet cam, but I am guessing it will be pretty much the same as both camshafts seem to making a similar noise. Any advice would be appreciated, does it sound like these bearings have had it. If so, how much are replacements?
Old Mar 6, 2005 | 10:16 PM
Nik_W's Avatar
Nik_W
bttt
Old Mar 6, 2005 | 10:44 PM
boost mad's Avatar
boost mad
when u say whiring noise, does it get faster as the rpm rises? and can u hear it inside the car or only when the bonnet is open?
Old Mar 6, 2005 | 10:58 PM
nikh667's Avatar
nikh667
By cam bearings i'm assuming you mean the two roller bearings directly behind the cam pulleys? Not heard of anyone having probs with these? I'd imaging they'd have to be pretty knackered to make any significant noise. Anyone else had probs with them?
Apart from that i'd check also the tension of the 2 alternator belts and PAS belt, make sure not overtight. Cambelt tension as a rough, rough guide can be checked by gently turning belt along its longest edge - should just turn about 90degs, any less then maybe too tight.
You can use a long screwdriver to "listen" to each surrounding compenent with engine running - to help pinpoint any poss bearing failure in water pump, alternator etc.. - BUT, only do this if you're confident - if you drop that 'driver onto the cambelt or any other rotating parts you'll be worse off!
BE WARNED - good luck!
Old Mar 7, 2005 | 12:28 AM
Stu @ M Developments's Avatar
PassionFords Creator
Cam bearings give plenty of trouble. Bin em, they are cheap.
Old Mar 7, 2005 | 06:19 AM
Nik_W's Avatar
Nik_W
Cheers Stu.
I took the alt and PAS belts off and ran the engine for a few seconds to eliminate those, and the noise was still there.
Old Mar 7, 2005 | 08:37 AM
Nik_W's Avatar
Nik_W
Just in case anyone is interested in prices, Ford sell the camshaft bearings for £8.50 + VAT which is cheaper than Burton Power I'll buy them and report back here to let you know if these solve the problem.
gingeRS
17
Oct 2, 2015 09:42 AM
Botts
Sep 22, 2015 02:04 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
Flateric_2002
Sep 15, 2015 08:41 AM
rsturbo27
Sep 5, 2015 05:08 PM
