zetec conversion temp gauge
Old Jul 24, 2011 | 05:26 PM
well2sound's Avatar
well2sound
Default zetec conversion temp gauge
Hi all
Just finishing off my conversion and was wondering how you get the temp gauge to work, ive put a 2 litre zetec in my mk4 xr3i. Also my rev counter isn't working, im using an esc pack as its on twin weber 40's. Any info would be helpful.
cheers
Old Jul 24, 2011 | 08:53 PM
The temp sender MUST be the one that was used originally, as it is likely to be a different resistance and so give false reading, so use the xr3i one, even if you need to make a adaptor to join the original temp sender to the new engine stat housing, unless by sheer good luck the new engine's one is the same resistance ?
I'm assuming you're using the std coilpack on the zetec ?, in which case see if there was a mk4 with a coilpack and use the tacho out of that is easiest way, my memory seems to tell me there was such a car/engine ?
Old Jul 25, 2011 | 03:51 PM
well2sound's Avatar
well2sound
Tabetha
Thanks I will try and find the correct tacho, im sure ive heard somewhere you can connect the esc pack up to the loom and it will work.
For the temp gauge i have used the temp sender from the xr3i and connectd it up to the loom but is still not giving a reading, maybe i should use the zetec one and somehow connect it up
Old Jul 26, 2011 | 05:31 PM
Originally Posted by well2sound
Tabetha
Does your zetec have a plastic stat housing, is that where the temp sender for the gauge is ?, it won't work without the sensor body itself being earthed, assuming your xr3i sender is a single wire ?
Old Jul 26, 2011 | 05:52 PM
well2sound's Avatar
well2sound
Ye its a plastic stat and thinking about it it has no earth so will be my first port of call!!
Old Jul 27, 2011 | 08:08 PM
Easily solved then with no cost, a bonus these days.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
