Clicking as I'm steering ?
Old Jul 19, 2011 | 06:00 PM
Bailes1992's Avatar
Bailes1992
Default Clicking as I'm steering ?
Someone try shed some light on this for me.
I have a clicking as I'm steering, mainly when I'm braking at the same time. Happens if I steer over 100° in either direction. It seems to be comming from the drivers side.
If I'm not braking then it dosen't usually happen, but usually when I'm slowing down and steering at the same time I get the click or crack noise?
It usually only happens the once, which is why I'm discounting the CV joints.
It's not a constant tick, tick when I move, it's just the one clunk or crack.
I recently had a new steering rack but it's been happening since before that.
I did fit new track rod ends though and I can't recall it happening before I fitted those?
Bailes.
Old Jul 25, 2011 | 12:05 PM
Bailes1992's Avatar
Bailes1992
And going back to the clikcing issue... is this normal?
Got some videos of the driveshafts on both sides. Seem to have a little play in them?
Drivers side...
Passengers side...
Other than that... no play or funny noises in any of the suspension.
Bailes.
Old Jul 25, 2011 | 12:16 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Your front springs arent snapped are they? This is a common reason for clunking. Or the strut top bearings could be seized
Old Jul 25, 2011 | 12:35 PM
Bailes1992's Avatar
Bailes1992
Theres no noise standing still, only when I'm braking and turning heavilly.
The strut seems to move smoothly and no play in the strut either?
Springs are fine too?
Old Jul 25, 2011 | 01:05 PM
phil_focus's Avatar
phil_focus
your vids look normal to me
as for the clicking/clunking its hard to say but as it was there before the rack was done then at least you can rule out the rack.
it might be worth stripping your front brakes down and cleaning them up. just calliper off, pads out, discs off, clean up, regrease and refit. might just be something caught in them or you might spot something during the job. just a thought as you say it happens mostly when on the brakes.
Old Jul 25, 2011 | 01:16 PM
Bailes1992's Avatar
Bailes1992
Thats the next plan of action I think. Just need to get a 7mm allen key socket for my torque wrench. Last time I had them out I just did the slide bolts up as tight as I could with an allen key, and it I always worried if I'd overtightened them or not tightened them enough etc.
How much are new slide bolts from ford? Wondering if they're worth replacing?
Old Jul 25, 2011 | 01:27 PM
phil_focus's Avatar
phil_focus
no need to replace the slide bolts, they just need to be nipped up. if you are worried about them coming lose then use some thread lock.
when the subframe was off were all the ball joints checked??
i've just replaced my rack on my mk1 2l focus btw, well worth doing and not too bad a job 8)
Old Jul 25, 2011 | 01:37 PM
Bailes1992's Avatar
Bailes1992
Mechanic did it in the end, he just dropped the back of the subframe. Just had the car in the air and theres no play or funny noises anywhere when the steerings going from one lock to the other.
Old Jul 25, 2011 | 01:44 PM
phil_focus's Avatar
phil_focus
strange one, hmmmmm. without hearing it then it will be next to imposible to tell what it is.
gie the brakes a try, and you never know that might sort it
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
dange
Sep 23, 2015 12:11 PM
