Cosworth diff.
Old Jul 14, 2011 | 01:10 PM
2wd's Avatar
2wd
Default Cosworth diff.
Hi quick question ... will a Scorpio 24V (Cosworth) rear diff be a direct fit on a 2wd Sapp. Cosworth ???
Old Jul 14, 2011 | 01:17 PM
martysmartie's Avatar
martysmartie
If it's 7.5" then almost certainly.
Martin
Old Jul 14, 2011 | 01:24 PM
2wd's Avatar
2wd
Well that hard for me to explain the brakers here in Dk ... they mostly know what year it came from ... so I need to find out if there is a difference in what year the Scorpio 24V are from ??
Old Jul 14, 2011 | 01:57 PM
R4N SS's Avatar
R4N SS
Just ask them to measure - will prob be easier.
it its a 7" diff you will need the shafts too
Old Jul 14, 2011 | 02:11 PM
S1-Tiz's Avatar
S1-Tiz
if its from the earlier one (NOT the bug eye one) Then yes they are ALL 7.5" 3.62 LSD diffs which are the same as 2wd sierra cosworth
Old Jul 14, 2011 | 02:40 PM
2wd's Avatar
2wd
Hi
ok so pre bug/frog eye they should be a direct fit ... do you know when they got face lifted ... 94-95 ???
about the ratio .. as I remember 2wd should be 3.64 ... ?
Old Jul 14, 2011 | 02:47 PM
S1-Tiz's Avatar
S1-Tiz
sorry i meant 3.64 i miss typed. They got facelifted in 95. you are looking for a 1992-1994 car for the correct diff.
Old Jul 14, 2011 | 02:48 PM
Weeksy's Avatar
Weeksy
All Mk3 Granada were 7.5 inch so I recall.
I didnt think the Grannies ran an LD, but I could be wrong...
3.64 for the 2.9 24v dude, better still is the 2.3 Ultima, with the lovely 3.91 final drive, just put one in mine
One word - fantastic!
Old Jul 14, 2011 | 02:52 PM
S1-Tiz's Avatar
S1-Tiz
but that will be an open diff! also speedo will be out.
All prefacelift 24vs ran an LSD seen way too many pulled apart now
All frog eyes were open
Old Jul 14, 2011 | 02:59 PM
Weeksy's Avatar
Weeksy
It works out about 9% fella. Yes they are open, but I only bought a CWP set, so kept my LSD.
Recalibration is only 50 quid, and it will prob be marginal from factory, so worth getting done. Who runs std wheel and tyre combos these days also!
I run a wheel and tyre profile with a greter rolling radius, so smaller difference on mine, but worth it seeing as motorists are the chosen means of revenue generation, and most of us drive these things to enjoy, that extra bit of accuracy is well worth it!
I stand corrected on the early cars having LSD's. Another Ford cost saving measure :-(
Old Jul 14, 2011 | 03:16 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Drive shaft flange is the wrong size.
You can change them from your old diff into the Granny Cossie one
Steve
Old Jul 14, 2011 | 03:30 PM
Mike Kerbey's Avatar
Mike Kerbey
I fitted one out of a bug eye, I had to chop a bit of the webbing off on the case, other than that, it was a straight swap. FLanges are the correct size aswell.
Old Jul 14, 2011 | 03:45 PM
2wd's Avatar
2wd
he he ok ..thourght so
So pre 95 it will be
Old Jul 14, 2011 | 03:47 PM
2wd's Avatar
2wd
So 3,91 .. what would that do to the speedo. ... ?
recalibration .. ??
So could I just find a 7½" ford diff with the prefered ratio and put in my lsd ... ?
Old Jul 14, 2011 | 03:53 PM
Weeksy's Avatar
Weeksy
I twould over read by about 9 percent on the std wheel and tyre combo, but as the rolling circumference grows, the different starts to diminsh... As I said, the speedo can be be recalibrated cheaply, so shouldn't put you off.
It really livens the car up, especially off boost. Best thing I have done to mine!
I found a Brand new CWP in Norway, for 100 quid, couldn't say no!
A used diff will be sweet, as the 2.3 only knocks out 140 odd horses...
Old Jul 14, 2011 | 05:15 PM
2wd's Avatar
2wd
hmmm ... you got me thinking ... I'll have look around and see what I find .. thanks
Old Jul 14, 2011 | 05:22 PM
Weeksy's Avatar
Weeksy
Good luck my friend.
Try and find a 2.3 Ultima and rob it of it's diff, they go for peanuts, see how you get on with the ratio, then maybe get your LSD in there with some bearings and seals - the perfect set up!
Weeksy
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Fezman1
Sep 7, 2015 09:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
