Cams
Old Apr 8, 2004 | 12:29 AM
Default Cams
Which is the best cam combo for a T3/T04 turbo on a YB?
BD16 inlet / standard exhaust
Pair BD 14s
Pair BD 10 (need to cut valve pockets?)
Old Apr 8, 2004 | 08:31 AM
Guinnless's Avatar
Guinnless
Not enough info mate.
Exhaust housing size? Compressor size? Injectors? Head porting?
BD14s and 16s need cutouts. BD10s do not.
Old Apr 8, 2004 | 03:10 PM
Turbo: .63 Stage 3 T3 Wheel with Garrett T04S housing 60-1 compressor AR .70 360 thrust bearing.
803 injectors but running microtech LT8S with 1000cc injectors soon. 75mm throttle body with custom veloctiy stack in intake manifold.
2WD Head to be ported: please advise where and how much to port...
Thanks!
Old Apr 8, 2004 | 08:12 PM
Guinnless's Avatar
Guinnless
Your turbo will only make around 400ish on 97 RON fuel. I'd say your stuck with BD10s at that level.
I doubt whether any tuners will give away head porting details. It doesn't help to pay the bills and mortage if you do
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
