Aftermarket ECUs for Cossie
Old Apr 8, 2004 | 12:27 AM
Default Aftermarket ECUs for Cossie
Has anyone any knowledge about aftermarket ECUs for the Cossie? I have shortlisted the Autronic SM2, Microtech LT8S or the Haltech E6X. Does anyone know who has used the above with good effect?
Old Apr 8, 2004 | 07:16 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Talk to Mark Shead of M.A.Developments as he is an authorised dealer of Auttronic Management or look on the website: http://www.madevelopments.com.
The other two i can't help you with.
Hope this helps.
Old Apr 9, 2004 | 04:05 PM
PJay's Avatar
PJay
Also SECS S8 is a NEW product developed especially for the cosworth market and should be looked at
Old Apr 9, 2004 | 04:35 PM
Can't find it on the net... How much does it cost?
Old Apr 9, 2004 | 04:39 PM
PJay's Avatar
PJay
Can't remember off the top of my head, do a searc on here as simon from secs is a member
Old Apr 9, 2004 | 04:51 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
My Tuner uses the Haltec,
I'm going to be using the Electromotive TECIII.
I've been hearing Great things about the Autronic and the secs unit as well
Old Apr 9, 2004 | 05:28 PM
Vic's Avatar
Vic
Singcos,
An aftermarket ECU is only as good as the installer and tuner.
I wouldn't use a Mircotech unless its a very basic all-out drag car. Then again, go for whatever your tuner has succesfully used before.
Old Apr 9, 2004 | 05:39 PM
Originally Posted by Vic
Singcos,
Why wouldn't you use microtech unless its an all out drag car? What about Haltech?
Old Apr 9, 2004 | 05:45 PM
Vic's Avatar
Vic
Mircotech isn't well known for its driveability on the road and you only get a limited number of load/tuning points. There is a reason why its cheap...
Haltech is better, but like I said make sure the tuner is comfortable with it.
Personally I would choose Autronic or Motec, but like anything, you get what you pay for.
Seeming that you're from Singapore I'm sure there would be some tuners there familar with these ECUs.
Old Apr 9, 2004 | 09:46 PM
What ECU are you using? Do know which Autronic tuner in Australia has the base maps for the Cossie? Do I need to install cam phase sensors and crank sensors? Thanks in advance!
Old Apr 9, 2004 | 10:03 PM
Hey Vic, drop me a mail... Have got tons of questions to ask you!
Old Apr 10, 2004 | 03:29 AM
go for the autronic get good reviews and you get what you pay for
Old Apr 10, 2004 | 03:59 AM
I'm running a Autronic SMC on my Escort Cossie. I've been really happy with it. Getting ready to retune it for the custom turbo and injectors I'll be installing soon.
Old Apr 10, 2004 | 05:25 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
Hi mtcossie!!! cool another Yank with a cossie!!
Old Apr 10, 2004 | 09:12 AM
Hi! Care to share the wiring details and whether any other sensors need to be bought/fixed/etc? Like cam phase and crank speed sensors? Did you purchase just the SMC kit or did you have to buy a load of other stuff like Autotune, CDI to make it run?
Thanks dude!
Old Apr 10, 2004 | 09:44 AM
Vic's Avatar
Vic
Singcos,
Email sent.
I would recommend you speak to the tuner/installer to gain confidence in them. There's no use in having one of the best ECU's when you're tuner has no idea... I would suggest you speak to a tuner first even before you choose an ECU.
You have been warned...
And no.. you don't HAVE to have CDI for Autronic
Old Apr 10, 2004 | 09:49 AM
Singcos,
Email sent.
I have 1 tuner who is very good with Microtech and Haltech and another one who is good with Autronic and Motec. Depending on what I buy, I will go to whichever tuner...
Old Apr 10, 2004 | 02:32 PM
Definitly finding a tuner familiar with the ECU will help a lot. Mark Shead helped me out a lot and I found a Autronic Dealer/Tuner (Davesport) close to me that helped with install and tuning. We used a MSD 6 for ignition control.
Fastmaul - good to hear from another Cossie owner on this side of the pond!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
