mtech v4 ecu
Old Jul 2, 2011 | 06:38 PM
cozi500's Avatar
cozi500
Default mtech v4 ecu
Hi all ive finally bit the bullet and got me sen a stand alone ecu the mtech v4, ive wired the loom into my RWD escort, the only wire im struggling with is from pin 11 on the ecu to the fuel pump relay, the diagram dosent show what it connects to. all the rest of the wiring is fitted and tested. mtech arent open sunday, so i cant ask them until then.
Old Jul 3, 2011 | 05:48 PM
If the ecu outputs a negative down this wire then terminal 85 of the relay, if it outputs a live down this wire then terminal 86.
Relay is wired,
85 = earth
86 = live
87 = output(live from 30 once "on")
It doesn't matter which way around 85 and 86 are so long as one is earth and the other live.
30 = input from battery via fuse, live input
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
