Deceleration fuel cut settings OMEX
Old Jun 25, 2011 | 06:01 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default Deceleration fuel cut settings OMEX
Hi currently running a 2ltr zetec with cams on omex 500 in my fiesta track car. I have the current deceleration fuel cut settings:
DFCO load 5
DFCO speed 15000rpm
I'm looking to change these settings to dump a bit of fuel in for a few secs on the over run at high revs (pop & flame)
Am I right in thinking i set the speed to say 5500rpm as the cut off point? (no dfco under this rpm), and leave the load as 5 as this is most likely off throttle??
Any help much appreciated
Brian.
Old Jul 1, 2011 | 12:27 PM
*Bri.4.b.Cos*
upski
Old Jul 3, 2011 | 05:50 PM
Just switch over run fuel cut off to OFF.
Old Jul 6, 2011 | 11:07 AM
*Bri.4.b.Cos*
i dont have that option, just the 2 settings in my OP
Old Jul 6, 2011 | 11:13 AM
OldDan's Avatar
OldDan
Mine was off above 2000rpm can't remember the kPa but for example in the omex manual it says "1600rpm / 1.17kPa"
It says underneath to disable the feature then set the settings at 25500rpm and 0 kPa
jay030787
Sep 18, 2015 07:34 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
