Cossie boost problem
Old Jun 23, 2011 | 10:36 PM
gaz3678's Avatar
gaz3678
Question Cossie boost problem
Help!!!
I've just replaced my original T34 with a brand new T34 with a 360 bearing and it doesn't seem to be producing enough boost. The car is on a stage 3 setup and was originally holding ~25 PSI before the turbo died.
On the first run out I couldn't get much more than 12PSI out of it so I changed the actuator for my old -31.
With it set as it had come off the old turbo I managed 14PSI. Tightened the rod and managed 15PSI. Contacted the turbo people and they sent me a -34 FOC which I installed. Initially it was holding 15PSI and 4 - 5 full turns of the actuator rod later, I am now holding 17PSI- with a -34!
I have put a compressor onto the actuator and I have a maximum of 5mm extension (no idea what pressure it starts moving, will get a regulator/ gauge and confirm tomorrow)- it seems I have very nearly forced the wastegate to be permanently closed.
Checked the intercooler for signs of a hole- as I had very similar symptoms once before and found a gaping split in the intercooler. I've checked the boost hoses and they are OK. Tried a different dump valve and lastly sprayed ez start over the intercooler and all boost hose joints in hope of identifying a leak/ hole., without success.
Run out of ideas, any suggestions before I take the turbo off and return it again????
Cheers!!
Old Jun 24, 2011 | 12:43 PM
Try plugging the actuator pipe onto the turbo itself, bypassing the amal.
Old Jun 24, 2011 | 04:19 PM
gaz3678's Avatar
gaz3678
Tried that, still no better. Got hold of a pump and the actuator starts to move at 20PSI, but it can only extend by about 4mm due to the amount of preload on there. Checked the I/C for holes, all OK.
Really not convinced that all is well due to the amount of preload on there.....
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
RsS2daz
Aug 14, 2015 05:26 AM
sjssms
Aug 2, 2015 07:01 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
