cvh blocks
Old Jun 22, 2011 | 10:19 PM
bythomson's Avatar
bythomson
Default cvh blocks
i have an xr3i engine, and a carb'd cvh from a mk3 , th emk3 engine has only 44.000 miles and is very clean , the xr3i engine is puffing smoke and smells oily when running and the owner had a bottle of oil in pass footwell ... burning oil i think, can i put the head off the 3i on the block of the carbd engine, there both 1600
Old Jun 23, 2011 | 04:53 PM
ChrisH's Avatar
ChrisH
You can but when the engine is in the car you've got the EFI wiring remember.
Old Jun 23, 2011 | 06:03 PM
bythomson's Avatar
bythomson
yeah transferring all the loom etc into a mk3 estate, give the engine a tickle whilst its out as its tired, using the low miles auto cvh bottom end and a rebuild on the top ed i think and a gasket set , water an oil pump for good measure
Old Jun 23, 2011 | 06:04 PM
Danster76's Avatar
Danster76
You would also need to add the provision for for crank pos sensor. But thats not a biggy with the bloke on the bench as it were.
Old Jun 23, 2011 | 07:35 PM
martysmartie's Avatar
martysmartie
The XR3 is most likely MFI, it was only the later ones that were EFI. You should be able to transfer the head. No wiring etc needs to be touched, you may if it's EFI need to drill a hole in the block for the CPS at the most.
In any case how do you know that the top end isn't at fault? Valve stem seals are a weak point on the CVH thus cause oil to be burnt, that is the usual suspect!
Martin
Old Jun 23, 2011 | 07:50 PM
bythomson's Avatar
bythomson
havent run it long enought o decide yet, always thought that if the smoke clears its the top end, if it stays its the rings but could be wrong , ???
Old Jun 23, 2011 | 08:27 PM
ChrisH's Avatar
ChrisH
Not necessarily.
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
