smokey escort van
Old Jun 7, 2011 | 09:17 AM
steel city pete's Avatar
steel city pete
Default smokey escort van
hey up fellas need some pointer,got a 2001 escort 55 van 1.8 endura engine,non turbo kicking black smoke out most of the time worse under load,got a new air filter in it so not that, whats my next stepsto cure it
Thanks for any help
Old Jun 7, 2011 | 09:33 AM
gouch1's Avatar
gouch1
try the cheap options fuel filter first
worst case could be your pump or engine internals
Old Jun 7, 2011 | 09:40 AM
steel city pete
ALL FOR THE CHEAP FIX FIRST MATE JUST NEED THE PLACES TO START FIRST,THANKS FOR YOUR STARTING POINT
Old Jun 7, 2011 | 09:42 AM
chaffe's Avatar
chaffe
Turbocharging Technician
what pump does it have on it? is it drive by wire or does it have a throttle cable? Wont be fuel filter, this will cause the opposite of black smoke
Old Jun 7, 2011 | 09:44 AM
steel city pete
Must say it runs sweet apart from smoke no nasty noises,ok on fuel dont use no oil or water,
Old Jun 7, 2011 | 09:47 AM
steel city pete
Not so sure on the pump mate,black smoke caused by over fueling so im told IS THIS RIGHT
Old Jun 7, 2011 | 09:49 AM
chaffe's Avatar
chaffe
yes, but you need to determine why min, does it have a throttle cable to the pump?
Old Jun 7, 2011 | 09:53 AM
steel city pete
Will try to find out buddy
Old Jun 7, 2011 | 10:03 AM
steel city pete
From what i can see it dose yes if its the right thing i,m looking at it has a cable stop on the end this i have just seen is loose on the cable end and there fore not ajusted may be,but just clutching at straws
Old Jun 7, 2011 | 10:06 AM
chaffe's Avatar
chaffe
work the throttle pedal and look for it moving ken
Old Jun 7, 2011 | 12:13 PM
steel city pete
worked the throttle and it pulls a lever under the bonnet is this on the pump housing, are we in the right area now sorry for my late responce
Old Jun 7, 2011 | 12:40 PM
chaffe's Avatar
chaffe
yeah mate, if its a bosch pump you will be able to screw the max fueling down and have a cleaner drive. Not sure why its changed though
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
markk
Sep 9, 2015 08:11 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Adam Graham
Sep 6, 2015 06:04 AM
Bighandsuk
Sep 2, 2015 05:23 PM
