not running
Old Jun 5, 2011 | 06:50 PM
markyr's Avatar
markyr
Default not running
Can anybody help please. i've just finished putting my 2wd saff back together after fitting all new gaskets, had head skimmed etc. Got cams, crank pulley and distributer TDC. but it will not run. It turns over and sparks, fuel is coming through but will not run. Can anybody help please..
Old Jun 5, 2011 | 07:04 PM
ChrisH's Avatar
ChrisH
Does it try to start?
Old Jun 5, 2011 | 07:05 PM
markyr's Avatar
markyr
Not realy it pops abit but that is it
Old Jun 5, 2011 | 07:38 PM
ChrisH's Avatar
ChrisH
By pop do you mean backfiring?
Old Jun 5, 2011 | 08:00 PM
markyr's Avatar
markyr
No backfiring just like a light popping when it's being turned over every now and then.
Old Jun 5, 2011 | 08:03 PM
ChrisH's Avatar
ChrisH
Where is the fuel getting through to? Do you mean the injectors are spraying or there is fuel at the end of the pipe?
Old Jun 5, 2011 | 08:13 PM
markyr's Avatar
markyr
No the fuel is getting through ok as i've taken the plugs out and the fuel is laying on top of the pistons.
Old Jun 6, 2011 | 09:22 PM
jacko996's Avatar
jacko996
Struggling to type on the mobile
Old Jun 6, 2011 | 09:24 PM
jacko996's Avatar
jacko996
Mark
just a thought mate
have u got.the injector plugs on the correct injectors ?
Come on guys , any more ideas as we have run out
told u it wasn't a good idea to get involved with cossies Lol
Old Jun 6, 2011 | 09:29 PM
fraser9764's Avatar
fraser9764
you sure you've got the dizzy timed correctly? using the lug on the pulley not the groove? and the centre of the rotor arm lined up the mark on the housing?
Old Jun 7, 2011 | 02:46 PM
markyr's Avatar
markyr
Yup all the injector plugs are on the right way round, and the rotor arm is center to the mark and the pointer on the distributor pulley is pointing at the distributor. But still no joy.
Old Jun 8, 2011 | 07:59 PM
markyr's Avatar
markyr
Sorry to sound stupid, but not sure what you mean by not having a needle sealed
Old Jun 8, 2011 | 08:53 PM
jacko996's Avatar
jacko996
Me neither Mark
Will.call u soon
Old Jun 8, 2011 | 11:06 PM
rscos2004's Avatar
rscos2004
Might be worth doing a compression check and make sure the pick-up in the dizzy is ok ive had this problem with mine recently and it was duff also double check all wiring is correct
Old Jun 8, 2011 | 11:44 PM
botters's Avatar
botters
competant bodger
are plug leads on in right order?
Old Jun 10, 2011 | 07:57 PM
markyr's Avatar
markyr
Thanks for all the suggestions i've tried everything but run out of time, as it is now on the trailer and i'm dropping it off to martin at reylands in the morning as it's going to be mapped. I will post up the reason for the fault when i know as it may be a help to someone in the future . Cheers Mark
Old Jun 17, 2011 | 11:16 PM
Joe Grp4 Escort's Avatar
Joe Grp4 Escort
What was the issue?
Old Jun 19, 2011 | 09:24 PM
markyr's Avatar
markyr
There was a lug missing from the crank pulley and also an after market chip that no one new about behind the glove box was playing up. so all sorted now and picking it up tomorrow.
Old Jun 27, 2011 | 09:14 PM
ray barker's Avatar
ray barker
get hold of tabetha she always posting on things like this shes very good
Old Jun 27, 2011 | 09:17 PM
BigErn's Avatar
BigErn
Tabetha is a bloke called Chris iirc
Old Jun 30, 2011 | 09:03 PM
ray barker's Avatar
ray barker
Default tabetha
chris shore nows is stuff easy mistake to make when you sighn of tabetha
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
