Has my alternator gone?
Old Jun 5, 2011 | 11:17 AM
C-Max1800Zetec's Avatar
C-Max1800Zetec
Default Has my alternator gone?
Hi there, can you guys help diagnose my cars problem?
I have a 2005 05 plate 1800 Zetec Focus C-Max, Yesterday I started hearing a whirring noise (like a mini's power steering pump) under the bonnet which rose in pitch with revs, then when driving home in the evening the battery light came on, the approaching a set of traffic lights at around 20mph the power steering warning came on, then when we stopped the car engine died. We restated it and this happened twice again until we got home (only 3 miles from the initial cut out). Started the car this morning to measure the voltage but sadly ammeter battery was dead so could not take a reading, when I went to start again it turned over once then went would not even turn and had the clicking relay noise.
I believe this is an alternator, a) is this correct and b) how easy will this be to change myself on this particular car.
Thanks for your help and sadly my first post on this site is not a positive one!
Old Jun 5, 2011 | 12:33 PM
ChrisH's Avatar
ChrisH
Check the auxillary belt is the correct tension, that whining noise would be a loose auxially belt 99% of the time, if it's loose, re tension, charge the battery and give it another go.
Old Jun 5, 2011 | 12:40 PM
C-Max1800Zetec
Thanks for that!
Old Jun 5, 2011 | 12:44 PM
ChrisH's Avatar
ChrisH
Not a problem.
Old Jun 5, 2011 | 01:12 PM
C-Max1800Zetec
Checked the belt and it seemed tight still, would this still be the tensioner.
Old Jun 5, 2011 | 03:26 PM
ChrisH's Avatar
ChrisH
Wants about 1/2 inch of play. If it's alright, i'd get a cheapo Multimeter and check it's alright. Also make sure all the terminals are tight, including battery.
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
