Actuator tuning
Hi I have a stage 3 T3 with a -34 actuator on it I which I need to adjust for more boost what way do you twist the end of the actuator? Is it way from it or towards the actuator? Cheers
Don't do it! You really need to have it set up properly, all too easy to whack the boost right up, which can cause it to run lean, then you have a melted engine on your hands...
SMILER258
Sep 28, 2015 09:04 AM
