Orion rs turbo conversion
Old May 30, 2011 | 01:01 PM
JONO_RST's Avatar
JONO_RST
Default Orion rs turbo conversion
Hi, i'm looking at converting all my 1989 escort rs turbo running gear (MFI) into a 1990 1.4 Orion over the next few weeks.
Is it best to put the full turbo car loom into the orion or just the engine wiring loom and join it to the orions original loom somewhere?
Also, i take it the engine and suspension ect are just a straight swap?
Any help would be appreciated.
Cheers Jono.
Old May 30, 2011 | 01:12 PM
mannion's Avatar
mannion
Swap everything over mate, full car loom, everything.
Old May 30, 2011 | 07:59 PM
JONO_RST's Avatar
JONO_RST
Cheers mate, i just wanted someone to confirm this before i start stripping all the loom out because i've heard of people splicing it etc.
Cheers Jono.
Old May 31, 2011 | 03:46 PM
mannion's Avatar
mannion
Easiest bet is disconnect everything in the bay then everything in the car from the back lights forwards, all interior and dash out. Once everything inside the car is completely disconnected you can carefully feed it up through the fusebox hole and out of the car then do the reverse to put it in the Orion.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
