focus anti-roll bar link rod
Old May 24, 2011 | 08:11 PM
splash550's Avatar
splash550
Default focus anti-roll bar link rod
Are mk1 focus front anti-roll bar link rods easy to fit? It looks like one nut each end or is there more to it? Are they under tension? Are they best replaced in pairs or doesn't it matter? Thanks guys!
Old May 25, 2011 | 04:08 PM
Best done in pairs, each side will have the same wear.
They are easier to replace than taking the wheel off to let you do it!!
It is just one nut each end, on the other side of the arm/strut to the nut is a thin nut shaped part so you can hold them still whilst undoing, sometimes the nuts just spin, or round off, if they do simply grind off.
I did both lower arms(tca), both struts, top bearings, springs, drop links pads discs all new on a mk1 recently, all in a day, oh and a wheel bearing, but that was a pig!!,
1 hour tops taking your time from start to finish will be plenty, for both sides.
Old May 25, 2011 | 04:39 PM
xrmalin's Avatar
xrmalin
I did my friends focus estate ones a couple of weeks ago and both the old ones and the new ones had a 5mm allen key hole in them for ease of removal and refitting
Old May 25, 2011 | 06:52 PM
Tis true they do have the allen key, tis also true that if tight this simply chews up.
Old May 25, 2011 | 09:40 PM
LewisT's Avatar
LewisT
my 03 focus only has the 5mm alley hole, bit of a bast@rd when you dont have allen sockets and my allen key is only about about as long as my index finger
Old May 25, 2011 | 10:41 PM
cabriolet's Avatar
cabriolet
really good pair of molegrips in behind them normally works for me worse case cut the nuts off with a angle grinder
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
hopper350
Sep 4, 2015 12:53 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
