00 focus indicator problems
Old May 21, 2011 | 07:12 PM
Barra's Avatar
Barra
Default 00 focus indicator problems
hi hows it, i just bough a 2000 1.8 tdi focus hatch. the turn signal indicator stopped working, first the left one went and about ten mins later so did the right one. i got the car to my workshop and i hit the hazards and everything is working fine, (the bulbs are working and flashing the 2 arrows in the cluster also work), so then i try the fuses all the fuses are ok. so i replace the stalk and still no joy so i try that stalk in a different focus and it works so its not the stalk. is there a flasher unit in these cars or are they controlled through the bcm module
there is no manual with the car so im not sure which fuses are which and the same goes for the relays i just pulled them all replaced all the 7.5 amps even if they were ok. any help would be sound cause me head is melted
thanks bar
Old May 21, 2011 | 08:55 PM
Sounds like a supply problem to the left stalk that controls indicators and dip/main.
See if you get a switched live wire when the ignition is turned from off to position 2(run), this may also be the same feed for the headlight flasher, so try that, does that work when pulling it back ?
Old May 21, 2011 | 09:03 PM
RichieST's Avatar
RichieST
Pretty sure on that year the flasher unit is built in to the hazard switch, so you could try changing that.
Old May 22, 2011 | 02:24 AM
Barra's Avatar
Barra
cheers lads, the dip/main beam works on the stalk but i changed it for a different stalk and i still had the same problem dip/mains working but no indicator. i didnt know that the flasher unit was in the hazard switch i will swopthe hazard and test the blocks for a live feed tomorrow and get back to yes
thanks
Old May 22, 2011 | 05:03 PM
Barra's Avatar
Barra
cheers richieST, turns out the connector block at the back of the hazard switch was loose but was making contact for the hazards but not the indicators i just pushed it home till it clicked and roberts yer fathers brother.
thanks for the help lads
bar
Old May 22, 2011 | 05:16 PM
RichieST's Avatar
RichieST
Glad it's sorted!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
dlwarrior
Aug 5, 2015 10:19 AM
