ST170 Focus Alarm!
Old May 16, 2011 | 05:40 PM
escortmad4eva's Avatar
escortmad4eva
booster
Default ST170 Focus Alarm!
Hi
I have a ST170 and the car alarm keeps going off i have bridged the bonnet switch but the bugger keeps going off!!! It normally starts going off in the afternoon about 2ish then can go off 7 times within the space of 20mins!
Please need some much needed advise i havent had the car long and its doing my nut in!!
Old May 17, 2011 | 07:08 PM
What alarm ?, is it a std ford fit one ?, does it not have LED reporting to let you know which area has triggered ?
Old May 17, 2011 | 07:22 PM
escortmad4eva
booster
its only a std no it doesnt have led its a 52 plate car
cheers
Old May 17, 2011 | 07:36 PM
wibbler's Avatar
wibbler
Interior light stuck on somewhere? Like in the boot? As I remember the battery saver could kick off the alarm if a light was on due to the load change.
Or possibly volumetric triggered as the car warms up in the day? Have an idea this could be from the boot vents not working correctly.
Though it's a long time since I had one so not 100% sure - got through 3 of the things so I saw most things at one time or another.
Old May 18, 2011 | 12:59 PM
Sp3no's Avatar
Sp3no
I had the exact same thing on my ST170, i bridged the bonnet switch and it stopped going off so got a new switch, if its not the bonnet do the same on the door and boot switches till you find out which one is faulty then replace it
If it is neither of these then disconnet the interior sensors located either side of the interior light
Old May 21, 2011 | 02:48 PM
escortmad4eva
booster
Hi right it has got to be the boot do u have to bypass or just un plug?
Old May 23, 2011 | 12:15 PM
Sp3no's Avatar
Sp3no
Unplug the sensor and as a temporary measure stick a wire between the plug connector to create a complete circuit. This will fool the alarm into thinking the boot is shut, i feel you pain mine used to wait till 3 or 4 in the morning before it started going off constantly, so i used to leave it unlocked but this meant dragging my ass out of bed and having to go out there and atleast open a door or it arms itself again
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Rammer46
Sep 18, 2015 08:31 AM
pie-face
Sep 15, 2015 10:43 AM
Iain Mac
Sep 13, 2015 09:16 PM
