Mk4 Escort Brake Bleeding Procedure
Old May 15, 2011 | 07:38 PM
jedi0_3's Avatar
jedi0_3
Default Mk4 Escort Brake Bleeding Procedure
Evening all.
What is the correct brake bleeding procedure for Mk4 Escort XR3I non ABS?
The Haynes manual says right hand front, left hand rear, left hand front, right hand rear.
(have no idea if left and right is when sat inside the car of stood outside looking at the bonnet)
Advice I have found on here says to work from furthest away i.e drivers rear, passenger rear, drivers front, passenger front.
Which one is right?
Thanks
Old May 15, 2011 | 07:58 PM
martysmartie's Avatar
martysmartie
General rule of the thumb is to always start furthest away from the master cylinder and work your way in, so offside rear, nearside rear, nearside front, offside front (Assuming your master cylinder is nearest the drivers side).
Martin
Old May 15, 2011 | 08:18 PM
jedi0_3's Avatar
jedi0_3
So why does the Haynes manual give a different procedure?
Old May 15, 2011 | 08:19 PM
I seriously haven't found it make any difference to 99% of cars, I always start nearest first, less walking that way, works for me!!
Old May 15, 2011 | 08:32 PM
jedi0_3's Avatar
jedi0_3
Fair enough.
Are the automatic brake bleed kits that use spare tyre air pressure any good?
Old May 15, 2011 | 08:38 PM
martysmartie
The Haynes for my car says to start furthest away and this is always the way I go about it but as said I don't think it's anything major, I personally would follow what the manual tells you to do!
Yes the Eezibleed by Gunson is quite good.
Martin
Old May 15, 2011 | 08:43 PM
jedi0_3's Avatar
jedi0_3
Thanks for all the help guys tonight.
Old May 17, 2011 | 07:22 PM
Gunsons eezibleed very very good, vacuum bleeders even better though, you can get a one man bleeder pipe, that has a slit in the end that opens under pressure to let fluid out, but seals shut when pressure stopped to stop air getting in, only a few £ and also really good.
Old May 31, 2011 | 07:52 PM
jedi0_3's Avatar
jedi0_3
Default MK4 XR3i Brake Bleeding
Probably a stupid question but when re-bleeding the entire system following fiment of new rear wheel cylinders I assume that the handbrake should be off?
Thanks
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
