MK6 running hot
Old Feb 8, 2005 | 11:47 AM
MaxUmis's Avatar
MaxUmis
Default MK6 running hot
I'll rather not share the gorry details of my experiences with SA Ford the last couple of weeks, Because it is not for sensitive readers, but I will say it involved having my car in the shop for two weeks to replace a head gasket, and a small fortune for ransom on the car.
Any way. I got my baby back, but now she is running VERY hot. So hot infact that I thought the radiator fan doesn't work! I took it back to the workshop where they were addiment that the Escorts do run that hot.!?
So since replacing the head gasket(anti-freez, and thermostat), the radiator fan only kicks in when the temp gauge reaches the "L" of "NORMAL"... It didn't used to get that hot...
So the question is, is there a way to get the fan to kick in sooner? I am skilled with a soldering iron, if it may be needed...
Old Feb 8, 2005 | 01:09 PM
DmcL's Avatar
DmcL
she a zetec i assume? none ive seen run that hot. you could try fitting a different thermostat or a manually controlled fan (switch in the dash jobbie).
rex647
Mar 6, 2022 06:20 AM
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
StephTell
Sep 2, 2015 06:31 PM
