missing
Old May 3, 2011 | 11:17 PM
bmp512's Avatar
bmp512
Default missing
lads, a wee problem my 2wd shappire has stated missing since put on a cone filter and 70 mm frontmount intercooler, its ok wen u feed the power in easy, but wen u floor it, it starts missing, the car runs geens with the standard t3, dnt think theres a uprated chip in it and a two bar map senor also. any ideas???????
Old May 4, 2011 | 04:17 PM
rs kev 500's Avatar
rs kev 500
Close plug gap up a bit more
Old May 4, 2011 | 06:23 PM
bmp512's Avatar
bmp512
new plugs fitted 1 month ago, motorcraft ones, were fine before parts were fitted, how much should i close them by????????
Old May 4, 2011 | 06:53 PM
rs kev 500's Avatar
rs kev 500
Bout 5 tho breathing better so boosting faster jus blows spark out had problem before
Old May 5, 2011 | 07:52 PM
bmp512's Avatar
bmp512
thanks lad will try this at the weekend,
Old May 5, 2011 | 10:37 PM
Alvyn's Avatar
Alvyn
what boost was it set at before and after(as sure it would of changed mate) I'd go get it set up now! also you say it's running (greens 803's or 355's???) without an uprated chip/map sensor??? are you sure?
Old May 8, 2011 | 09:24 PM
bmp512's Avatar
bmp512
Missing is sorted closed cap on plugs, fine now , car is boosting to 22 psi, pulls well,
Checked the chip today, has a superchip fitted! It has wrote on the top of the chip in pen ( sap 2wd p1 STD) also has printed on it the numbers 27999,,, theres a code on the casing of the brain weber Iaw , Italy 045, W45.06/lL20-67, wot does all this mean?? Also checked the injectors there greens, also a code on them 0280150355, i take it that the last 3 digets mean that I have 355's, map sensor is black think that is a two bar 1???
Old May 9, 2011 | 08:19 PM
bmp512's Avatar
bmp512
Is my car is running stage 1? Wot bhp would it b??
Old May 10, 2011 | 06:02 PM
rs kev 500's Avatar
rs kev 500
I'd say around 280-300 ish
Old May 10, 2011 | 08:47 PM
bmp512's Avatar
bmp512
cheers lad
Old May 11, 2011 | 08:54 AM
bmp512's Avatar
bmp512
Should I fit a 3 bar map sensor now? Or maybe buy one and keep it till I maybe upgrade to stage 3, do I need to upgrade the ecu as well, sort off all new to this!
Old May 11, 2011 | 06:24 PM
DAN400's Avatar
DAN400
fuck you have nt a clue you homo
need to learn how to drive a stage 1 before you go to stage 3 pmsl
Old May 11, 2011 | 09:14 PM
bmp512's Avatar
bmp512
lad ur a twat, wen ever u get urs built again ill show how to drive it not like u, u ole woman
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fil
Sep 30, 2015 12:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
