help on zetec timing
Old May 1, 2011 | 08:38 AM
scottymoo's Avatar
scottymoo
Default help on zetec timing
hi
went to change the cam belt on a 1.6 zetec focus had it locked off when the tensioner snapped and moved the cams can any one help me as there are no timing marks at all
thanks
scott
Old May 1, 2011 | 08:42 AM
saph4be's Avatar
saph4be
if i remember right you take the cam cover off and at the back off the cams you can lock them off in the correct place with a flat bar or spanner
Old May 1, 2011 | 08:43 AM
saph4be's Avatar
saph4be
what year is it and i'll check autodata mate
Old May 1, 2011 | 11:20 AM
zippyobrien's Avatar
zippyobrien
Floating pulleys, so u slack all the pulleys of, use the timing pins and tension the belt
Old May 1, 2011 | 01:15 PM
On the other end of the cams you'll find a 6mm slot cut into each cam, it is offset as well, so when a 6mm rod, or locking bar is placed across the head top surface and into the cams they are correct, use the correct locking pin for the crank web, most don't undo the cams when doing these, I always do personally, makes sure it is correct in case it wasn't prior to doing the belt.
Billy_RS
16
Oct 11, 2025 09:41 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
robnock
Aug 22, 2015 10:51 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
