2wd clutch question
Old Apr 22, 2011 | 04:00 PM
1cosworth's Avatar
1cosworth
Default 2wd clutch question
i ve red that a lot of people with cossys with about 300 to 360 bhp change just the clutch with a six pudle ap for ex. and keep the ford cover plate.is this hybrid thing any good? thanks forders!
Old Apr 22, 2011 | 04:06 PM
fraser9764's Avatar
fraser9764
mine is currently only 300 and ive just had to change the clutch as the old one let go on the dyno, ive fitted an AP 6paddle with an AP heavy duty cover. no complaints here, the peddle is far lighter than the old knackered clutch, and its not too bad pulling away when you get used to it.
Just make sure you get your flywheel skimmed.
Old Apr 22, 2011 | 04:17 PM
1cosworth's Avatar
1cosworth
i was thinking for the whole ap kit but its around 500 euros so i m thinking twice just in case i can skip the 500 with another solution .
Old Apr 22, 2011 | 06:39 PM
There are two different covers/diaphragms supplied by ford, one is good and ok for well over 400bhp, the other is only just adequate for std power, I can't remember which is which though.
This is a common clutch combo though.
Old Apr 22, 2011 | 06:56 PM
fraser9764's Avatar
fraser9764
well i was told that the ford clutch's made by borg and beck were good for decent power levels, but the borg and beck that came out of mine still looked fairly healthy, no oil contamination, plenty of meat left on the friction plate etc. and couldnt hold 300bhp/320lb/ft. Personally, i wouldnt bother trying to save money, buy the AP/helix/Alcon 6 paddle and heavy duty cover and forget about it.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
yatta
May 21, 2016 10:31 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
