Turbo wrap or heat shield
Old Feb 7, 2005 | 04:09 PM
smoothrs's Avatar
smoothrs
Default Turbo wrap or heat shield
Is it safe to use heat wrap on the back of the turbo and zorst.
or should I stick to a heat shield??????
Old Feb 7, 2005 | 09:50 PM
velocity's Avatar
velocity
u can use heat wrap,but the heat shield is the way foward the shield helps keep the glowing zorst heat from damaging the brake componants,it also helps to direct the heat out the r/h bonnet vent if fitted,and i have seen both used together
Old Feb 8, 2005 | 03:40 PM
smoothrs's Avatar
smoothrs
Thanks
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
