CVH Cylinder Head
Old Feb 6, 2005 | 07:49 PM
orion_rs's Avatar
orion_rs
Default CVH Cylinder Head
I'm suspecting that my RST cylinder head has a crack somewhere because I keep hearing bubbles of water after I switch off the engine until it cools down, even though I've got the swirl pot.... which means compression is leaking from somewhere.
I found a 1.9 CVH (USA) modified cylinder head for a bargain. Is this the same as the 1.6 CVH head? If not what differences does it have? Thanks
Old Feb 6, 2005 | 08:23 PM
Alvyn's Avatar
Alvyn
is it loosing water then or getting hot loads of cvh's make that noise(bubbling in the hoses) just around the thermostat etc when a tad hot
Nov 1, 2015 06:53 PM
