Is 1.3 rad sufficient
Old Feb 25, 2011 | 09:35 AM
mobb-black's Avatar
mobb-black
Default Is 1.3 rad sufficient
I have a 2.0 zetec in what was once a mk4 1.3 fezzy, will the original 1.3 rad I have be ok or should I get hold of a bigger one? Like say from a 1.8 etc?
Any help appreciated
Dave
Old Feb 25, 2011 | 09:48 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'd get a bigger one in there if i were you, no sense keeping a smaller one if there is a direct fitting larger one.
Old Feb 25, 2011 | 10:29 AM
mobb-black's Avatar
mobb-black
I dunno if there is a direct fitting larger one, I guess it'd be from something like a Zetec S or a Puma
Old Feb 25, 2011 | 11:25 AM
fezzielove's Avatar
fezzielove
have you thought about fitting a saxo vts rad
Old Feb 25, 2011 | 12:03 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you could use an rs turbo one, one from a later car running on a zetec.
wouldn't be hard to make it fit and pipe it up.
saxo rads are ok, but you have to fit a bleed point high up in the cooling system as they don't self bleed like the standard header tanks.
Old Feb 25, 2011 | 12:04 PM
mobb-black's Avatar
mobb-black
fezzielove the vts job sounds like a winner lol
Old Feb 25, 2011 | 12:37 PM
fezzielove's Avatar
fezzielove
its a short vad with a wide core plus header tank is built into the rad we did this on the mk1 and im doing this on the escort as the bay is all smooth with no wiring visable
mk3ste
Oct 17, 2021 10:09 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
Ben26
Sep 3, 2015 07:55 PM
