Zetec Engine Wiring
Old Feb 17, 2011 | 10:57 PM
Steve_RS's Avatar
Steve_RS
Default Zetec Engine Wiring
I know this has probably been done to death in the past, but I can't find the info that matches the loom I've got here. This loom seems to have more wires in the plug than anyone mentions on the net.
The usual scenario - 1.8 Zetec into a mk4 scort using Fez Si loom & non-pats ECU.
Got a 12 pin plug that requires feeding with power etc....
Can anyone provide a definitive list of what these wires need connecting to, to work:
Plug:
Pin 1 - Brown
Pin 2 - Green
Pin 3 - Brown
Pin 4 - Black
Pin 5 - Black/Red
Pin 6 - Red
Pin 7 - Black
Pin 8 - Black/Green
Pin 9 - Brown/White
Pin10 - Brown/Green
Pin11 - Black/White
Pin12 - Brown
Any idiot-proof info is very much appreciated as this is the last thing to be done now....
Many thanks in advance,
Steve.
Old Feb 18, 2011 | 09:06 AM
JonathanJ's Avatar
JonathanJ
right , the connector is C1980
Plug: Car / Engine
Pin 1 - Brown
Pin 2 - Green Rev Counter / Pin 11 DIS
Pin 3 - Brown Fuel pump relay / pin 22 ECU
Pin 4 - Black Ign Switch / Pin 2 Coil
Pin 5 - Black/Red Fuse 20 / Hego
Pin 6 - Red Fuse 1 / Pin 1 ECU
Pin 7 - Black
Pin 8 - Black/Green Injection Relay / feed to ecu + sensors
Pin 9 - Brown/White
Pin10 - Brown/Green
Pin11 - Black/White
Pin12 - Brown
Will trace the rest later , and edit , will repost when I have done it
Old Feb 19, 2011 | 07:20 PM
Steve_RS's Avatar
Steve_RS
So... the bits I can understand so far...
12Way Plug:
Pin 1 - Brown -
Pin 2 - Green - Connect to Escort Mk4 Tachometer
Pin 3 - Brown -
Pin 4 - Black - Connect to +12v Ignition Switch (with an inline fuse)
Pin 5 - Black/Red
Pin 6 - Red - Connect to +12v (with an inline fuse)
Pin 7 - Black -
Pin 8 - Black/Green -
Pin 9 - Brown/White -
Pin10 - Brown/Green -
Pin11 - Black/White -
Pin12 - Brown -
Anyone else care to add anything? Would like to hear from someone whose fitted a zetec using a Fiesta Si loom to confirm its going to work as I dont want to damage the ECU as they're pigs to find non-pats ones these days.
Old Feb 19, 2011 | 09:45 PM
JonathanJ's Avatar
JonathanJ
I have the original ford wiring diagram here , and I aint that far away from you
Old Feb 19, 2011 | 10:35 PM
Steve_RS's Avatar
Steve_RS
Have just downloaded a copy of Autodata and Im having a browse....
Time to get the meter out on the loom and see what needs powering up etc...
Am I right in thinking Pin 22 ECU I should wire to the coil (earth side) of the fuel pump relay (to switch the relay on)
Old Feb 20, 2011 | 07:22 AM
JonathanJ's Avatar
JonathanJ
That is what it shows on mine as well Steve
Old Feb 15, 2015 | 05:06 PM
Michael420's Avatar
Michael420
Default Ford fiesta
Hi I don't know if u can help me but
I have a fiesta that I race and I have just put a 1600 zetec x reg I have put the loom in ecu transponder and the key but it seems like the mobiliser is staying on I have power to The ignition but when I try to start it dose not start can any one help
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
muz
Aug 16, 2015 12:57 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
turbobill
Aug 1, 2015 08:55 PM
