mk4 gearbox
Old Feb 3, 2005 | 12:06 PM
16vzetec's Avatar
16vzetec
Default mk4 gearbox
i have a mk4 escort 1.3 with a 5 speed box.
is this the same box as the xr3i?
will it have the same size clutch and fly wheel?
mike
Old Feb 3, 2005 | 08:32 PM
b13nde's Avatar
b13nde
the box is the same fords dont change much the box on a rst is the same apart from the lsd thats why the dam things carnt stay together i would say the clucth is the same but check at your local motor factors
Old Feb 4, 2005 | 12:00 PM
JesseT's Avatar
JesseT
Clutch and flywheel are different. Box is the same apart from maybe the ratios.
Old Feb 8, 2005 | 10:35 PM
16vzetec's Avatar
16vzetec
if the rst has 220 clutch and flywheel and the same style box then how does the starter motor meet up with the flywheel if the flywheel is smaller than a rst item?
Old Feb 9, 2005 | 05:33 AM
JesseT's Avatar
JesseT
diameter is the same on all flywheels. It's about what size clutch they are machined to accept.
Old Feb 9, 2005 | 08:11 AM
16vzetec's Avatar
16vzetec
so will a rst clutch and flywheel fit on to the crank of my 1.3 ohv engine??
Old Feb 9, 2005 | 08:24 AM
Hrsturbo's Avatar
Hrsturbo
I would have thought so yes but don't quote me on it!!
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
