overheating focus
Old Feb 13, 2011 | 02:21 PM
cabriolet's Avatar
cabriolet
Default overheating focus
as above it overheats when u turn it off the gauge drops really rapidly it also goes up to the red instantly done thermostat done water pump flushed cooling system ? any ideas fellas
Old Feb 13, 2011 | 05:38 PM
Is it actually overheating or just the gauge saying it is ?
Does it use water, push it out the expansion tank etc, heater blow hot and cold etc etc.
It could just be a lecky issue affecting the gauge/s rather than a actual real cooling issue, more details needed.
Old Feb 13, 2011 | 05:41 PM
martysmartie's Avatar
martysmartie
Do the cooling fans activate? (The info to do so is received by the same sensor that supplies the gauge reading )
Martin
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
