ZT compression ratio
Old Feb 9, 2011 | 09:19 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Default ZT compression ratio
since i'm getting custom sized wiseco pistons made up (already paid for just need to confirm ratio).
what would be the best ratio to aim for?
i thought an 8:1 would give me plenty of scope for bigger power later on, but an 8.5:1 would give a little more power for boost.
i don't really want to drop any lower as i don't think i'll be on the edge of sensibility anytime soon, but will have eagle rods, area six cams/springs, arp rod bolts and arp main studs too.
just after an opinion on anyone who has done this as all searches vary from 8:1, 8.2:1 and 8.5:1.
i will be in touch with an engine builder to do the boring out of the block etc.
but only whe pistons arrive in the next four to five weeks.
only got a 2.5BAR map sensor, so limiting factor of 21psi ish boost for the near future.
cheers
sean
Old Feb 9, 2011 | 09:21 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
my comp ratio is 8.1-1 and drives very well atm. its only on a base map but is still very responsive off boost
Old Feb 10, 2011 | 12:53 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'll stick with a ratio of 8:1, i will probably raise it a touch with the block being skimmed for good measure no doubt.
Old Feb 10, 2011 | 05:05 PM
Sp3no's Avatar
Sp3no
Impossible to say exactly what your comp ratio will be without cc ing the head. Specially with a skim. If your skimmimg the head go for 8.0-1
Old Feb 10, 2011 | 05:10 PM
crazycage's Avatar
crazycage
i would spec it so it's 8-5-1 on the standard focus rs gasket then if you want to drop it a little all you need to do is fit a st170 head gasket.
mine is 8-7-1.
Old Feb 10, 2011 | 05:13 PM
Sp3no's Avatar
Sp3no
I was under the impression all the 2.0l head gaskets were the same
Old Feb 10, 2011 | 05:17 PM
crazycage's Avatar
crazycage
no mate the focus rs one is 0.6mm the st170 is 1.1mm and i have a few 1.8mm ones thats are ford also.
Old Feb 12, 2011 | 01:43 PM
robnock's Avatar
robnock
escort gti turbo
wot does all this ratio mean wot is better lower or higher
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
