escort gti running problem help!!!
Old Jan 31, 2011 | 05:47 PM
nralden's Avatar
nralden
Default escort gti running problem help!!!
Here goes,
sorry for the essay
ive got a 1998 escort gti it wasnt idling properly when first started it was hunting then when I was stopping a traffic lights the revs were dropping to arround 500 rpm it was drinking like anything doing about 18 mpg,
so I did a bit of research and thought id clean out the idle controll valve so I did that today and while I was doing that cleaned the throttle body as it had all black build up in it and was a bit corroded, oh also the inlet manifolf had a big puddle of petrol in it.
so I got it all back together and now the car starts up at about 2000 rpm on all four then the revs drop to nearly dying point then chugs on two cylinders and but if I put the revs up myself it goes up fine but then gradualy goes down and misfires like anything.
all hoses pipes and wires are all on properly aswell,
please help me sombody,thanks in advance neil.
Old Jan 31, 2011 | 06:15 PM
oldford's Avatar
oldford
With a puddle of petrol in the inlet manifold, the car is massively over fueling.
Can be defective injector or wiring, which causes it to be open all the time.
Or a leak in the exhaust leading to false readings from the Oxygen sensor, or a defective oxygen sensor. I have seen a fuel pressure regulator that was blocked and that lead to a fuel pressure more than 2 times what is normal.
Take it to a professional before you kill the engine.
After repairs are finished change the oil and oil filter. There's probably a lot of petrol in it.
Old Jan 31, 2011 | 07:00 PM
nralden's Avatar
nralden
Its just strange that now ive cleaned it al out its running so much worse, ive got the car off the road atm as thats one of the jobs on my long list of things to do
Old Jan 31, 2011 | 08:42 PM
nralden's Avatar
nralden
Help, anyone know why it would get worse after cleaning out idle controll and throttle body
Old Jan 31, 2011 | 09:57 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Have you tried resetting the ecu? If its used to running on certain readings but getting total different ones now then fueling etc will be all over the place
Old Jan 31, 2011 | 10:09 PM
nralden's Avatar
nralden
I didnt know that you can do that, never heard of it, what do you do?
Old Jan 31, 2011 | 10:15 PM
Camel Fiddler
On the focus's you unplug battery for 30mins (radio code may be needed if factory radio), then start it up and let it idle for 10mins with lights, heated window, blowers on and every so often rev the engine- gentle at first then more vigorous and then finally go for a bit of a drive. But as I'm used to focus, I'd wait if someone escort orientated comments if this works or not first.
Old Jan 31, 2011 | 10:22 PM
Turbo Pez's Avatar
Turbo Pez
Like said try resetting ecu, mine did the same, so unpluged batteryed for a couple of hours, i heard it only needs 10mins but i did a few hours to be sure, then started it up and let it idle, ran spot on afterwards!
P.s i put a new idle valve on....but tried cleaning trick 1st but didnt reset ecu, so could of saved meself 50squid!
Old Jan 31, 2011 | 10:28 PM
nralden's Avatar
nralden
Thanks for the help ill give that a go tomorow an see if that cures it,
Old Feb 1, 2011 | 02:54 PM
nralden's Avatar
nralden
Help it still isnt working,i took the battery off this morning then left it about 3 hours and tryed as I was told but its still starting on 4 cylinders at high revs then dropping down to 2 cylinders like its not getting fuel into it but smells really rich, ive not done anything apart from what I said to it,
has anyone else got any ideas please,
neil.
Old Feb 2, 2011 | 08:12 AM
nralden's Avatar
nralden
Help anyone please
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
Zoggon
Aug 10, 2015 10:39 AM
