cossie stoppers on s2 plz look!
i have searched all posts about brakes n cant find what im askin... and i know this is asked a lot but im not another goon askin without lookin
cossie 2wd calipers apparently all you have to do is machine off 4mm where caliper mounts to hub so standerd rims can b used... am i correct?
then its what disk to use is it the 4x4 or the 2wd disk.
2wd disk is 283mm
4x4 disk is 278mm
well again "apparently" i cant go bigger then 278mm
but will the smaller disk sit right in the caliper??
lol this is doin me head in so will some1 plz kick me n tell me which go with what lol
cheeRS Ric.
2wd disk is 283mm
4x4 disk is 278mm
cheeRS Ric.
You have to fit a different brake pipe/adapter because the pipe would be coming out of the caliper towards the drive shaft (2wd cos- rear wheel drive). Think you need some sort of 90degree elbow.
cheers moonie already thought of that 1 sorted some elbows at work!
any1 else got some info on which disks to use n if there anymore works needed on caliper to get it on?
cheers Ric
cheers Ric
Russ Payne
25-09-2015 08:29 PM
