crunchy gears
Old Mar 29, 2004 | 08:42 PM
Default crunchy gears
everytime i line up and launch the cossy i can never get it in second gear
when i need it
ive just had the box reconed for the 6th time this year
cud it be down to linkage or clutch im runnin alcon 6 paddle with ford release bearing
im only running 330bhp aswell
Old Mar 29, 2004 | 09:04 PM
Dave Henshall's Avatar
Dave Henshall
t5 or mt75 ?
the mt75 doesnt like to be rushed ive found - what oil are you using...?
Old Mar 29, 2004 | 09:15 PM
Switch's Avatar
Switch
is it an alcon cover and plate? if so u should be using their release bearing.
Old Mar 29, 2004 | 09:27 PM
Dave Henshall
they dont list one though in the kit and recommend an OE one - even the kit for the evos is the same - factroy release bearing - if they do one then, it must be thicker to allow the fork to push it furthin into the diaphragm...
Old Mar 29, 2004 | 10:17 PM
its an mt75 box
ive been woundering if it cud be the release bearing but cannot find an extended version anywhere
its an absolute nightmare espically when ur lining up against another car
Old Mar 29, 2004 | 10:19 PM
sorry it is an alcon cove and plate
i dont know what oil im using as athe company who reconed the box fitted it
Old Mar 30, 2004 | 06:34 AM
Dave Henshall
might be worth droppin the box oil and filling it with some proper MT75 oil - cheapest ans easiest option first.....
Old Mar 30, 2004 | 11:33 AM
would that be normal atf fluid, i think the gearbox plce say use engine oil
Old Mar 30, 2004 | 12:43 PM
Dave Henshall
normal atf fluid hell no!
mt75 fluid has some special polmers and constituancy specifacally for the mt75 box - funnily enough.
atf fluid can be used in the transfer box though.
Old Mar 30, 2004 | 03:58 PM
WHERE WOULD I GET THIS FLUID FROM
Old Mar 31, 2004 | 07:06 AM
Dave Henshall
most motor factor places will be able to get it - comma castrol and various other companies do it - including ford
Old Mar 31, 2004 | 03:50 PM
thanx ill give it a go see what happens
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
