Wiring loom
Old Feb 1, 2005 | 09:27 PM
Chris-S2's Avatar
Chris-S2
Default Wiring loom
I've got a Escort Turbo and i want to get rid of the mfi unti and all the loom, is there an easy way to do this? I've started but i'm no expert and now i just have a big bundle of wires hanging in the engine bay.
Any tips, information and links welcome
Chris
Old Feb 3, 2005 | 05:41 PM
sammy's Avatar
sammy
take it your moving to efi then, you need fiesta rst engine loom, ecu, sensors, inlet manifold & throttle body complete, theres probably some other bits & bobs to. first you need to find out what to do about the crank sensor though.
Old Feb 3, 2005 | 08:27 PM
b13nde's Avatar
b13nde
done it to mine strip out the loom and trace all the wires back all you
need under there is fan loom temp sensor earths reverse swicth
chargeing loom starter loom head lamps and power supply wipers
brake res sensor indiacator loom just follow all the wires under the
bonnet to each item the fuel and main ecu have a lot of the loom
going to them which is sensors and swicthes try this when you
open the loom you will see
Old Feb 4, 2005 | 09:51 PM
s3rst's Avatar
s3rst
initialy went for the 1.8 cvh tdc senser on mine... using sierra bottom pully n alt pulley.
cuttin the loom back can get messy... good luck! i found working from the ecus back worked ok
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
