2WD COSSIE NOISY ACTUATOR
Old Mar 29, 2004 | 05:09 PM
Default 2WD COSSIE NOISY ACTUATOR
I recently posted a problem with a blowing exhaust problem from the back of the turbo/downpipe,i think i have righted that problem,but have now realised that part of the noise i thought was the blow is actually the inside of the actuator rattling,it is worse at idle and at low revs.does anybody know what this could be?thankyou
Old Mar 30, 2004 | 07:46 PM
cossie400's Avatar
cossie400
Are you sure it is not the wastegate? if there is not enough pre-load it will rattle, either a week actuator or has not been adjusted right
Old Apr 1, 2004 | 08:57 PM
You sure its not the turbo damper? do you have a std ford spring item, it may need adjusting/replacing if it turns out not to be the actuator? Does it change pitch then disappear when you rev it higher?
mark r
Sep 29, 2015 07:27 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
