Max boost for a cosworth 2.9?
Old Feb 1, 2005 | 05:49 PM
extra14's Avatar
extra14
Default Max boost for a cosworth 2.9?
I`m running a cosworth v6 engine on standard compresssion (9.7 to 1 I believe) , with sequential twin turbo. (T3, ihi RHB5 turbos).
What I want to know is what is the maximium boost i can run safely, i have been told 8psi. Anyone here running a turbo V6 on standard compression?
I will set my display to inject water at 4psi 35C.
If I set water injection to be on regerdless of temp at say 7 psi for detonation control will I be able to up the boost much?
I plan to use 0.6mm water jet at 100psi.
Thanks
Darren
Old Feb 1, 2005 | 06:06 PM
extra14's Avatar
extra14
I will run a charge cooler so the intake temps should be low, about 30C.
If i do decide to lower the compression can anyone recommend where to go for pistons, or anyone who makes custom rods?
Thanks
Darren
Old Feb 1, 2005 | 07:09 PM
Mr.h.'s Avatar
Mr.h.
I know its a bit naughty mate but u could try posting this in general as more people use that
Some really helpful chaps on here
Indyrs
20
Sep 1, 2015 09:04 AM
blackbeautyzetec
Aug 29, 2015 02:11 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
